跳转到主内容
The Xperia Z1 Compact is Sony's premium camera phone. It is similar to the Xperia Z1 model except smaller and less expensive. Its key feature is a 20.7 megapixel sensor. Upon release the available colors were white, black, pink, and lime. This device can be identified using the model number (D5503)
29 个问题 查看全部
Is it possible replace the battery?
I'm going to buy a Z1 Compact but I have always used smartphone with a replaceable battery. When the battery will be useless, is it possible to change it in a Customer Assistant Shop? Or will I need to buy a new smartphone?
Thank you!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 8
添加一条评论
3个答案
最有帮助的答案
Yes, it's possible. You can have a look at Sony Xperia Z1 Compact teardown in advance.
这个答案有帮助吗?
得分 6
1条评论:
I have the same problem, my battery fully charged but once disconnected from mains, turns itself off. I backed up my phone to laptop and reset but now it just switches on/off/on/off. I do not know what teardown in advance? Please help! Thank you
完成的
添加一条评论
My problem was when received call via facebook, my phone suddenly black out & automatically switch off. After that i try to switch it on back but unable to do so even my phone is fully charged. And when i connected my phone to the charger, it's shows nothing & unable to charge. Is it my battery problem? Thank you!
这个答案有帮助吗?
得分 0
添加一条评论
I wont to change batry my z1 mobile
这个答案有帮助吗?
得分 0
1条评论:
I wont to change batry my mobile
完成的
添加一条评论
添加你的答案
Clare 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 5
过去 30 天: 8
总计 40,574
