跳转到主内容
非苹果电脑键盘维修指南。
How to repair charging port?
When I last went to plug in my micro USB charger into my Zagg universal Bluetooth keyboard, the charging port was pushed further back into the keyboard. How do I take it apart to repair this device? There are no visible screws anywhere.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 6
添加一条评论
4个答案
最有帮助的答案
I just took mine apart. Use a heat gun to soften the adhesive, and slowly remove the rubber, then the case will seprate. The mirco USB connector is weak, and I have had several fail already. this part would otherwise be easy to replace, as it clips on, but Zagg will not sell the part. I may try to bypass the port, and charge directly to the battery...
这个答案有帮助吗?
得分 1
添加一条评论
Not sure if this will help but here it goes. The connection was very loose and cable would fall out. The port was not loose, just seated far back. I took a file and filed down the cable plastic on the connector so it angled properly in relation to the case and port. Problem solved.
这个答案有帮助吗?
得分 1
添加一条评论
Bought a new keyboard after mi puts roba
这个答案有帮助吗?
得分 0
添加一条评论
it broke off during normal use plus the wand has stopped working
这个答案有帮助吗?
得分 0
1条评论:
were do i buy new keyboard and wand
完成的
添加一条评论
添加你的答案
Lucas 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 15
过去 30 天: 74
总计 5,501
