跳转到主内容
A general purpose laptop released in 2010 with a 15.6" screen.
18 个问题 查看全部
问题已关闭
What is error code 0xa000000e.
triing to reset to factory settings with acer recovery dics
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
1条评论:
could you post a picture or is this simply a popup Error:0xa000000e.?
完成的
添加一条评论
2个答案
That is a recovery install failure error.
You may need another copy of your disk.
这个答案有帮助吗?
得分 0
1条评论:
I got another set of recovery disks from Acer, still having the same error code show up . I put my own password ln for f-2. how do I return it back to default setting? Maybe that might make a difference
完成的
添加一条评论
I have a acer aspire to and i had the same problem i had corrupted or missing files try running a system scan i use sfc/scannow/f in the command prompt admin that will check your system files and repair broken or missing files also run a antivirus programm that worked for me.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 425
