跳转到主内容
replace 2009 MacBook Pro Logicboard with 2010 Logicboard?
Hi, i have here a Macbook Pro 13-inch from 2009 with a faulty Logicboard, i found a Logicboard of a 2010 13-inch Macbook Pro on Ebay and read somewhere that those two could be used in both cases. Can someone confirm this? That would be super-handy, because then i kind of would have a working AND upgraded Macbook Pro :)
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
no one can help me on this one?
完成的
添加一条评论
3个答案
已选择的解决方案
Jonah, Sorry I just didn't see your question before now.
Generally you can only replace logic boards within the same series. In this case these are the systems within your '09 model: MacBookPro5,5. Here's is the '10 models: MacBookPro7,1.
Often Apple moves things around enough to make it hard to force fit even similar systems. I've not personally tried doing this on this series so I can't say its not possible, just be aware you're a trailblazer here.
Here's the Guides for both review them carefully before you start:
Good Luck!
MacBook Pro 13" Unibody Mid 2009 Logic Board图片
指南
MacBook Pro 13" Unibody Mid 2009 Logic Board Replacement
难度:
困难
40 minutes - 2 hours
MacBook Pro 13" Unibody Mid 2010 Logic Board图片
指南
MacBook Pro 13" Unibody Mid 2010 Logic Board Replacement
难度:
中等
1 - 3 hours
这个答案有帮助吗?
得分 3
5条评论:
thanks a lot!
完成的
so there are no problems whatsoever? no problems with mic, webcam cable, or anything? That would be great news indeed!
完成的
Did you managed to make this change? i have the exact same 2 boards
完成的
yes i did! it all worked :)
完成的
How is that working @ Jonah , i might do the same to my mid 2009 Model .
完成的
添加一条评论
My macbook Pro 2010 is out of order for two years due to logic board can it be replaced. please
这个答案有帮助吗?
得分 0
2条评论:
Reply please
完成的
Hi,
Both 2009 and 2010 are compatible, i did the replacement myself.
完成的
添加一条评论
hi pagamim you just change the logic board? my 2009 core 2 duo model can be core i5 is that correct? thank you
这个答案有帮助吗?
得分 0
1条评论:
core 2 duo and i5 are 2 different generations, different bus speed, different memory. Not compatible within the macs 2010 and 2009. These two will take only core 2 duo processors
完成的
添加一条评论
添加你的答案
jojojonjon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 11
总计 3,917
