Why won't my Nintendo 2DS power on?
After charging my device overnight,when turning the power switch to ON, the 2DS screen remains black and the power LED remains unlit.
The Nintendo 2DS is a handheld gaming device developed as an entry level version of the Nintendo 3DS with nearly identical hardware, but without the 3D upper screen function.
Had this happen to my son's 2DS today, and I was able to fix it. For clarity's sake, my issue was this: no matter if the 2DS was connected to the AC adapter or not, when the power button was pressed, the blue LED would light for a couple of seconds and then extinguish. If you listened closely, you could hear the speaker "pop" when the LED turned off.
How did I fix it? Follow along:
评论:
Thanks, even though the ribbons appeared to be in properly, I removed them and placed back in and that did the trick!
由 Neil Davidson 完成的
já tentei muitas vezes e não consegui ligar
由 thiagopereira10000 完成的
Além de assegurar que os dois conectores no centro da placa de circuito impresso são limpos, em linha reta, e firmemente no lugar, eu não sei o que mais a recomendar...
A sua bateria tem quaisquer sinais de degradação? Você pode detectar todas as outras questões sobre a placa de circuito impresso? Há uma tampa de metal sobre o processador, se for solto, ele pode causar problemas, bem como...
Deixe-me saber o que você descobrir!
由 Zac 完成的
Na tentativa de limpar as telas do meu 2ds, eu tirei as duas fitas da placa mãe do console. E após montar ele novamente não consegui ligar e sempre fazendo pop depois de 3 segundos.
I had the same symptoms, started to open it up, but just took the battery out, cleaned the contacts and put it back in, to check. And voilà, it started up just fine. Seems contacts weren't coping with the current of start up.
由 eledbile 完成的
It would be helpful to know more about your problem, but for general reference this troubleshooting guide has some information on your problem.
评论:
My Nintendo 2ds won't charge every time I take the charger off it says low battery then I left it charging for about 2 days and I turned it on But the orange light
Was still there and nothing happened so I took it off the charger tried again but there was no light or anything. This has been happening ever since my dad changed the battery. So what do I do? Please help me.
由 Hana Baig 完成的
I juat bought a nintendo 2ds on ebay but its not turning on after pressing the power button
Do i need to charge it or something else
Please help me out with it
由 Bhavya Gala 完成的
I had this same issue. It seemed to work again after I removed the back, reseated the battery back in, but the was a metallic rattle in the inside. When I took off the back fully there was a silver colored metal plate that had come unsoldered. Anyone know what the function of that plate was? 2ds turns on without it in there but need to know if it could cause issues if not put back on. Don't want any hazards.
评论:
Im trying your suggestion. Will let you know.
由 Eve Ward 完成的
What size screwdriver did you use?
由 Nico Lozano 完成的
the metal plate is just to cover the processor and other components. it is not need so i would recommend learning how to take apart your 2ds and just removing it all together. hope this helped.
由 Mark Wiens 完成的
I had my 2ds for 1 and a half year but the system has been charged and was working perfectly but 2 hours later it wasn't working no liquid have been spilt on the device, SD card inserted, and device is fully charged.
Please help me fix my 2ds.
My 2ds is the one thing I spent a lot of money on.
声誉积分: 1
声誉积分: 1
声誉积分: 1
声誉积分: 1
I have a 2ds Xl i got around Christmas I moved out of my moms and came back a month later to get it but it would turn on only the blue light for a second and a pop noise.
Now i read all these comments tried removing and reinserting all the ribbons inside, Took the battery out and put it back and still nothing. Any more tasks I could perform would be much appreciated Thank you!
声誉积分: 1
声誉积分: 1
声誉积分: 1
声誉积分: 1
Make sure the battery is making contact. My son dropped his and afterwards didn't work. I took the back top cover off. The two very small screws if you can find a screwdriver that size. I took up the slop in battery compartment by folding a small piece of paper towel behind and doubled up to put pressure against battery and prongs. Works fine again.
过去的24小时: 15
过去的7天: 127
过去的30天: 732
总计 90,627
Does the light indicating it is charging come on when you attach the charger? Has this been exposed to liquid? Have foreign objects been inserted into the cartridge slot? Have you ever seen this unit work properly Please give us more about the history of this game system.
由 ABCellars 完成的
My son has been using the 2DS devise for from almost 2 years. unfortunately the devise is not starting now even after a complete charge. Please advise.
由 Harjeet Seehra 完成的
i have a problom my 2DS charges and the light is on but it won't display my screen
由 Colin Lewis 完成的
Can you help me my 2ds charging light turns on when I charge it but the light comes on for a few seconds and my 2ds turn on light won't turn on at all and my 2ds won't open please help me
由 darkacorn921 完成的
I think there may be something loose on the motherboard with my 2 yr old 2d's, does anyone know what the name of the big silver plate is?
由 Dara Bradley 完成的
显示更多的21条评论
