跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Audio jack not working
Hello everyone!
I am posting to ask about my iPhone's audio jack not working. I am sure something burned, but I don't know what to replace. It happened when I knowledgeably connected a "Satellite only" port to the audio jack. It started making noises and then it stopped the music playing. Anyway, the phone became really hot, but luckily there was no other harm to the devise. After that, I read online that if the audio was not working I needed to replace it. The piece that I replaced included the antenna and the charging port. Unfortunately the audio jack was still not working after the repair.
I would really appreciate if I would get help. I reiterate that that is the only problem. The loudspeaker actually still works. The only audio source not working is the audio jack
Thank you in advance! :)
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论:
Same here, found a solution yet?
完成的
Similar issue on an iphone 5. After a few repairs, the jack stopped working. Replacing the jack did not fix the issue
完成的
Sounds like board damage if the actually replaced part need not resolve the issue.
完成的
添加一条评论
1个答案
No, I didn't find a solution. I have another phone now, so I just gave up on fixing the other one. I have no idea what was wrong with it. It could have been something more expensive. Now I'll just be more careful with my experimentations.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
David Lopez 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 154
