跳转到主内容
Microsoft Surface Pro 系列二合一平板电脑的维修指南和信息。
573 个问题 查看全部
Can I replace the USB port on the surface pro?
I have a bent pin in the surface pro usb port that sometimes will recognize devices, but other times not. Is it possible to replace the port or is it soldered into the motherboard which would make it more effort than it's worth? Thanks!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
It will be soldered onto the motherboard. not necessarily more effort than its worth but if you've never done it i would not recommend it.
这个答案有帮助吗?
得分 0
添加一条评论
Pullg the off screen and digitizer are most likely going to wreck the screen and are a major undertaking. Unless the screen is already cracked I don't recommend trying it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 2
总计 3,786
