跳转到主内容
东芝所制造的笔记本电脑。
1273 个问题 查看全部
Black screen after login?
So when I start up my laptop, everything seems fine. When I log in it takes a while whit the "welcome" loading. When it finally loads, the screen is black! Anything that pops up shows (like task manager and whatnot) but other than that it's just black. I can see my cursor and it isn't blinking. Help! It's a really frustrating thing and I've tried unplugging it, taking out the battery, holding the power and all that, still no desktop screen. This just randomly happened out of no where. One day I start it up no problem, the next it didn't work. Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
1. Plug in a second monitor just to test and see what is actually happening.
2. bring up the windows run bar, type cmd in the box.
3. type control Ncpa.cpl users inside the command window.
4 navigate to display options and set defaults.
Let me know if this helps?
这个答案有帮助吗?
得分 0
3条评论:
Can you please give an answer that doesn’t require a second monitor?
完成的
so, you can open command prompt?
完成的
it fixed. go to task manager, stop your malware, go to files ad delete it.
完成的
添加一条评论
Same thing happened to me. Same model, b7t running windows ten. I waited a while and the cmd prompt opened. After awhile, it was working. No idea. Your best hope is a recovery drive. If you don’t have a usb, your dead. Sorry for the death.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Braedon 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,149
