跳转到主内容
Repair guides and troubleshooting for the Acer Aspire V5, a series of laptops on the Windows OS by Acer.
132 个问题 查看全部
Screen black out after signing in
The laptop is on and all the flash light showed power on. Then it lead me to the sign in page which is normal. Then after signing in, it should be jump to the desktop but it didn't. It continue black out but I see the arrow moving without lag and I can still see McFree notification at the bottom without failure.
P/s: I was downloading Microsoft office online before this happen. I click the button reboot when the pop up of finish installation.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Hi,
You can try to repair Windows from the Troubleshoot menu. To enter this menu you will need Recovery drive. How to do this, you can see in this video:
http://youtu.be/bha-wf0FT0k
Try first with "Automatic repair" or "System restore".
Finely you can made "Refresh your PC". ds.This will safe your personal data but will remove all installed applications.
Regar
这个答案有帮助吗?
得分 1
添加一条评论
As you said you were downloading the Microsoft Office online maybe a virus has attacked your computer system leading to corruption of data. There are various manual methods available but they wont provide you a solution in case of severe corruption.For this you have to resort to various third party software's which are easy to install and have shown good results. If you are a bit confused regarding selection then I would first recommend you using Windows data Recovery by SysInfoTools . There are others also available like stellerinfo and kernel but since I have personally used SysInfo and it worked fantastically well I recommend you to first try it out and later look for other options
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Apple Chin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 522
