跳转到主内容
The Xperia Z1 Compact is Sony's premium camera phone. It is similar to the Xperia Z1 model except smaller and less expensive. Its key feature is a 20.7 megapixel sensor. Upon release the available colors were white, black, pink, and lime. This device can be identified using the model number (D5503)
Replace Z1C screen with Z3C screen?
I would like to request about the feasibility of replacing the screen on a Z1 compact with a Z3 compact screen + digitizer.
Z1c dimensions are the same except for the thickness of the phone, but the inside + connecters of the screen design might be the same? Screen resolution is the same at 1280x720, so hardware wise I assume it would be compatible.
Thanks in advance, it would be a great upgrade possibility especially for cracked z1c screens!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
5个答案
最有帮助的答案
There are some other specifications should be payed attention such as the position of the hole for front camera and sensor. Also different cables, different sizes of LCD and different style of earpiece.So i suppose they are not compatible.
这个答案有帮助吗?
得分 2
添加一条评论
Thanks for your response, still wondering if anyone would try modding one onto the z1c :)
这个答案有帮助吗?
得分 0
添加一条评论
hi there !! i have a sony xperia z1 compact, but i have a trouble on my touch screen have a zone on the top of the screen that it's no working , i immersed the phone on the water, what can i do ? have to change all the touch screen or can just made something easier !! Thanks .
这个答案有帮助吗?
得分 0
添加一条评论
The screens also have different number of pixels, so I would advise against it
这个答案有帮助吗?
得分 0
添加一条评论
Sony xperia z1 compact screen is not compatible with z3 compact. their screen flex cable is different. If you using the z3 compact screen to install on the z1 compact, maybe it will damage your phone. so i'm not recommend you to do this.
We offer Sony xperia z1 compact lcd screen and Sony xperia z3 compact lcd screen. and we also provide the repair tools and repair guide to help you.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bart 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 13
总计 2,950
