跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
iPhone 5 gets vertical lines on the screen and then reset.
Iphone 5 two years old, no jailbreak, gets vertical lines on the screen and then reset(Sometimes the screen turns red),several times in a day and then working properly for one full day.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Sasa,
Has your phone been worked on before, such as a screen replacement or anything else? It sounds like a boot loop caused by board damage. I've had a 5S come in for repair doing the same thing you are describing. Please let me know what type of work this device has had performed on it in the past.
If no work has ever been done, and if you are sure the device has not been opened before, then did you purchase this phone new or refurbished?
这个答案有帮助吗?
得分 1
1条评论:
Hi, Eric,
Thanks for your answer. I changed case and battery one year ago (NOT official Apple repair) and everything work well until now. Today my iphone has worked without problems, but yesterday restart several times, once when is on standby, once when use it, once when have incomin call, no some rules...
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 6,663
