跳转到主内容
Released April 2013, model numbers GT-N5100 (3G & Wifi), GT-N5110 (Wifi), and GT-N5120 (3G, 4G/LTE & Wifi)
76 个问题 查看全部
Is there any chance of repairing or replacing the battery connector?
When replacing the battery in my Samsung Galaxy Note 8.0 the black piece of the battery connector broke in half. Now it doesn't have enough force to hold the pins down to make a reliable connection. The device only works when plugged in. As soon as I unplug, the device powers off. Any tips would be great. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
That was the 1st thing I tried. It worked for about a month. I ended up soldering the contacts.
这个答案有帮助吗?
得分 0
添加一条评论
if you bought the phone within the past year or two it should be covered under warranty with the company that you purchased it from. speak with them about it
这个答案有帮助吗?
得分 0
添加一条评论
Just fixed mine. Looking around, it seems the Samsung repair depot will solder the contacts (battery and wire connector) together. This will be a reasonable fix until you need to replace the battery again.
My solution was to take a small patch of EVA foam and double sided foam tape just big enough to cover the terminal. Apply this to the top of the battery cable connection.The back of the tablet casing should press on the foam enough to keep the contacts together and the tape will stick to the outside of the tablet battery connector.
Time will tell if this is a reasonable long term solution.
(I wish I could post a pic of this.)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
B J 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 7
总计 392
