跳转到主内容
What can I do? iPod washed? No hope?
iPod went through the wash, Head phones and all. I let it dry out and have it sitting in rice currently..
It will come on, but after doing so the click wheel and other buttons won't respond at all. Except it will let me reset (menu + center) Should I just let it dry out more or is there something else wrong?
When connected to the computer, everything works fine, all files are there.
Any advice at all is sincerely appreciated!!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
2个答案
已选择的解决方案
there is only one option to handle it - but after all - the iPod could be lost.
you need a few things in order to fix it
  1. isopropyl alcohol (>90%)
  2. a soft paintbrush
  3. tools to open the nano
use the logic board guide to disassemble the nano, the needed tools are listed in the guide, there might be other working things to open it, but with the mentioned toolset - you're on the safest side.
after you removed the logic board, clean the "odd" looking parts with the alcohol/paintbrush
the fluid residue will look white/greenish and is conductive - it will shortens the parts and thats why it must be removed
be careful, the tiny parts are very fragile
check/clean all connectors and chips
it's not that easy when you do it for the first time - but in most cases - it works
这个答案有帮助吗?
得分 0
添加一条评论
If you open the ipod you can try a gentle blast with a warm hairdryer to completely dry out the board first, before using the alcohol. try it once it is dry.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
PennyForUrPenny 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 4
总计 2,611
