跳转到主内容
Repair guides and troubleshooting for the HP Chromebook, an 14 inch HP-brand laptop computer that runs on the Chrome operating system (OS).
Unable to charge chromebook
My son's HP chromebook's charging ability got worse and over a few months last year, to the point that it does not charge at all. The cables have been demonstrated to be working. Has anyone attempted to fix the issue - I'm guessing that the charging port "desoldered" from the board but I haven't had the chance to take it apart yet.
Thanks!
Keith.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
2条评论
I have the same issue, and getting ready to toss it too.
Not good, because the laptop isn't even a year old.
Warranty was 90 days
完成的
I work at a school doing chrombook repairs. We honestly haven’t found a reliable source for 14” batteries that are reliable. Most of them fail and have awful battery life. The 11” are the best we’ve found.
完成的
添加一条评论
4个答案
已选择的解决方案
I also have this issue my Chrome book will not charge at all I am going to attempt to replace the dc jack if you have the model number q020nr I believe the dc jack is replaceable with out soldering.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I have had this problem as well on multiple occasions, even after sending the Chromebook in for a replacement. It appears to be a serious defect for the device.
I've tried jiggling and wrapping the cord around the computer, with mixed results. At this point, I may simply throw the computer in the garbage and get a Samsung model.
这个答案有帮助吗?
得分 1
添加一条评论
I had the same thing happen to me. I opened up the Chromebook, and did some poking around. Everything looked fine. I put the device back together again, and it started charging again. I probably caused “Embedded Controller” to reset as in this article https://thedroidguy.com/2018/05/troubles...
这个答案有帮助吗?
得分 1
添加一条评论
I have had this problem most of the time the solution is to do a hard reset which is done by holding the power and refresh keys for 10 seconds
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
kmattox 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 18
总计 4,459
