跳转到主内容
Fix that arm clock using one of our handy guides!
56 个问题 查看全部
New battery for SkyCaddie GPS Watch?
I am trying to change the battery on my Skycaddie GPS watch. Can anybody assist with the model / serial number of this battery? and where I can find it on the internet. The only other batteries I find are related to handheld GPS devices and not the Skycaddie watch.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
最有帮助的答案
I was able to replace my battery with battery found on ebay. 3.7V 300mAh Rechargeable Lipo Battery Pack PCM 602030 High Rate for MP3 MP4 . You must cut connect off old battery and solder on to new battery. Watch working great. My recommendation is you measure the physical dimensions of your watch battery to make sure same as this battery. Mine was, easy replacement.
这个答案有帮助吗?
得分 1
1条评论:
Where did you purchase this battery?
完成的
添加一条评论
I have a Skycaddie sport watch.
Battery has always been bad....I decided to change it out.
Battery:
1.11wh CE UL
new 452530 3.7v
300mah 131009
I am having no luck finding the replacement...I would appreciate any help given.
Thx,
Ross
这个答案有帮助吗?
得分 0
1条评论:
Did you ever find the battery for your Sky Caddie 360? I need one for mine if you could pass on the information. Battery:
1.11wh CE UL
new 452530 3.7v
300mah 131009 < our number (140625) all else was the same
Thanks Jerry
完成的
添加一条评论
where did you get this battery from?
这个答案有帮助吗?
得分 0
1条评论:
it came with the watch
完成的
添加一条评论
添加你的答案
Kincaid 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 7
总计 1,745
