跳转到主内容
加入维修社区 - 创建账户
第四代iPhone。维修过程直观易懂,但前置玻璃和LCD面板无法分开,只能作为同一零件更换。GSM版本, 8, 16, or 32 GB 容量 / 型号 A1332 / 黑色或白色
问题已关闭
Why does my speaker doesn't work?
my iphone 4 speaker is not working I already tested the sound chip by doing a bridge between the two pins in the dock and an aux cable connected to a random speaker and by testing the speaker of the iphone by doing a bridge between it and an ipod/or a computer and it did work.
I also did a bridge between the iphone and its speaker but with no results
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
Hello Marco, it sounds like your device has a faulty charge port assembly which is causing your problem. That or your headphone jack flex cable is damaged and causing the speaker to not function. Just to be sure, I would replace both cables and check your work.
Heres some guides to help
Headphone jack flex
Charge port assembly
Hope this helps, Good luck mate!
Cheers!
iPhone 4 Dock Connector图片
指南
iPhone 4 Dock Connector Replacement
难度:
困难
45 minutes - 1 hour
iPhone 4 Headphone Jack & Volume Control Cable图片
指南
iPhone 4 Headphone Jack & Volume Control Cable Replacement
难度:
困难
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 94
