跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
I get error 9 and blue screen on restore after battery replacement
I get error 9 and blue screen on iPhone 5S when I try to restore the phone. The phone doesn`t even get from apple logo to recovery (I tried several times). I replaced the battery and the phone died...
I made a video to show you what`s happening
https://www.youtube.com/watch?v=a9Db0W7s...
And yes, I know about this issue, the tracks looks untouched.
https://irepairnational.files.wordpress....
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
8个答案
You mixed the screws up on emi sheild
这个答案有帮助吗?
得分 0
1条评论:
I checked the tracks with a microscope and they are ok.
完成的
添加一条评论
Were the screws mixed?
Only reason for blue screen is mixed screws so there must be damage you cannot see
这个答案有帮助吗?
得分 0
1条评论:
Hmmm, only that screw place should be the problem? I mean there is no damage...
完成的
添加一条评论
I'm having the same exact issue. And, I was SUPER careful about which screws I took out and where they were located. I checked again tonight and the long screw was always in the same hole it was supposed to be in. What else could this be? I disconnected and reconnected all of the plugs I took off several times.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem in my phone. How do I fix it?
Help me ..
这个答案有帮助吗?
得分 0
添加一条评论
I'm having this exact problem without the phone ever having been opened. That makes me doubt the claim that only cause could be mixed screws. My phonehasn't ever been dropped or gotten wet either.
What could be another cause of the blue screen / reboot-cycle?
这个答案有帮助吗?
得分 0
添加一条评论
Whats's up I have a big problem with my iphone 5s, My iphone was broke with bluescreen and I fix it now is working but after 4 days that I fix it I've changed 3 sim cards because my iphone was killing them, now is killing the frontface camera the microfone even the charger port that I'm actually charging in one side of cable :S I don't know what to do. I want to restore to check it would it be that problem but I'm scared that it would broke even more iphone with any error or something. Any solution please ???
这个答案有帮助吗?
得分 0
添加一条评论
The Blue Screen is just a error report.
The screws are one cause but any hardware damage can cause this screen. Check your board for missing components. Battery replacement you may have pried a part loose on the board.
Also I see many iPhone when dropped they can shock or break parts off the board at times.
这个答案有帮助吗?
得分 0
添加一条评论
I am having this same problem ONLY with the ifixit replacement battery. I have changed the battery back to the older one and no problem, but once i put the ifixit battery back in, every couple minutes the phone will blue screen and restart.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Alex 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 2,292
