跳转到主内容
Wifi No Hardware Installed
I am not getting wifi. I had a no hardware installed message, before i reinstalled OS X. Now i don't even have a wifi option. Bluetooth and I sight works fine.
What I've tried so far. Ive replaced the wifi card. Same result
Next I ordere a used cable and tried that without removing the display and attaching one end of the cable to the i sight camera. This gave me no wifi or bluetooth (or i sight because i didn't hook that end up ) I thought this cable may be defective so i ordered another one. Same result. Do i potentially have three bad cables, or do the two "new" ones have to bee connected to i sight in order for wifi and bluetooth to work. Thank you in advance.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
Check the card connector. Someone here with similar problems found out that they had bent a pin on the connector (they too tried multiple cards). Fortunately they were able to straighten the pin without breaking it off.
If this answer is acceptable please remember to return and mark it accepted.
这个答案有帮助吗?
得分 2
2条评论:
I inspected both sides of the connector they look good.
完成的
Did you use a mirror and a light and look inside the slot?
完成的
添加一条评论
添加你的答案
Kent 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 11
总计 1,090
