跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
display brightness not increasing or decreasing
I have a samsung galaxy s3 i9300. Its screen got cracked so gave it to a local repairer.he replaced the whole display and touch.the touch is working fine but now the display brightness is neither increasing nor decreasing. So my question is.is there any problem in display?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 12
1条评论
sir mera samsung j5 ki brightness work nehi kar rahi ha ji kya karu ma plz.. mare problem ko solve karo ji
完成的
添加一条评论
10个答案
最有帮助的答案
The replacement screen u got is an lcd whereas the original one is an led.thats why the brightness cannot be controlled
这个答案有帮助吗?
得分 7
2条评论:
but there aren't a solutions for brightness check with an led display?
完成的
I would have believed this until I used a 3rd party app to check control brightness, that worked perfectly fine. I would try a phone reset but right now using the app.
完成的
添加一条评论
Hi Nitish,
Are you sure auto-brightness is not activated?
Perhaps energy saving is enabled?
To test everything with your screen i suggest you launch the test menu and see if everything works there, there is a special button called "dimming" there to test as such;
-> go to your "keypad" (as if you want to call somebody)
-> Type in: *#0*#
It should start the test menu instantly.
Let us know what the tests do :)
这个答案有帮助吗?
得分 3
1条评论:
In dimming test it showing three colours. Red,blue and green. Nothing else is happening
完成的
添加一条评论
go to play stor install apk name NIGHT MODE it can be easly fixed
ukrain rx
这个答案有帮助吗?
得分 2
添加一条评论
If you have replaced your display folder then sometimes you face this problem , because of cheap quality display folder .
For this you have to download night mode application from play store .It will work for you.
这个答案有帮助吗?
得分 2
添加一条评论
Reset your device and off the auto power saving and try again
I think its work unless there is a hardware problem
这个答案有帮助吗?
得分 0
添加一条评论
If you have changed your phone display then it might create problem because some china display doesn't have the hardware that support display brightness. If not so then try factory data reset this might work.
这个答案有帮助吗?
得分 0
添加一条评论
Yes bro u are right? This happens to me also,it is only because shop owner replace not the original folder infact any third class , cheaper folder?
这个答案有帮助吗?
得分 0
添加一条评论
My mobile brightness not increase problem samsung j7
这个答案有帮助吗?
得分 0
添加一条评论
First check the auto brightness option,This is the symbol of copy Lcd only to display the graphic not controlled light system and phone also goes to heating up problem better to change original OLED LCD.
这个答案有帮助吗?
得分 0
添加一条评论
brightness not working samung c7000
Update (09/17/2019)
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
nitish tokas 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 24
总计 43,345
