跳转到主内容
PlayStation 3 Slim是PS3的第二个迭代机型,机器型号CECH-2000。索尼电脑娱乐推出此机型来修复初代“胖机”PS3的诸多硬件问题,于2009年9月1日发布。
Why won't my PS3 Slim eject discs?
My PS3 does not eject discs. When you put in a disc, it accepts them, but very slowly. Then, it won't eject them. Also, and this could be key information, the manual eject feature (where you pull off that tab on the bottom of the console where the blue screw is, then insert a screwdriver in the hole and turn counterclockwise to slowly eject the disc) will not work either. I took apart the Blu Ray drive and everything and there is a part that appears to be a bit wonky. I don't know what it is called but it is described at 3:05 in this video:
https://www.youtube.com/watch?v=Oh5kmcoI...
The part is off center and down, and even when I put in a disc it will not move up like it should. I couldn't find anything wrong with it other than that it appeared to be in the wrong position. Otherwise, I have tried resetting the mechanism and everything that he does in the video but it does not work. The Blu Ray reads games that are in, but just can't eject them. I have scoured the internet for a fix to this and can't find one, and don't want to pay for something that seems like an easy fix.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
I can only eject the disk manually. and like the fellow above the screw driver trick will not work even though it is one of the models on the list..It will work then it won't work.So I know it's capable of doing it's job but it seems it don't have the juice to eject the disk. and it's not on the list in what to do or things to try like some others that shows more details. The charge to send it in for repairs I mias well buy a new one with the shipping,parts and the taxes a new one sounds more reasonable but even the price of a good one comes in a bundle what I don't need. Is there someone out there that has fixed this and is able to close the system back together.
完成的
添加一条评论
6个答案
最有帮助的答案
Hey guys, spent a lot of time today deep cleaning my entire ps3 slim, and once finished and I got everything assembled. The disc tray stopped ejecting discs, it accepted them no problem except the fact it was accepting the disc rather slowly. I went on opening and trying every little thing I could even as far as reassembling the disc drive, but with no prevail. Then I realized something very telling. THE FELT PROTECTING THE DISC DRIVE BECAME STIFF AFTER ALL THOSE YEARS!! I ripped off the felt around the disc drive opening and BOOM! Perfect fix!
这个答案有帮助吗?
得分 3
1条评论:
I've often thought that may be the problem, I'm going to take it off mine too. Makes perfect sense thanks
完成的
添加一条评论
If you still have this issue i found that while trying to use the manual eject the disc was catching on the felt thing on the bottom (not sure how to describe it best) so i used a knife and lifted this disc up and it ejected. and now when i insert a disc it goes faster, before it would go in really slow. Hope that helps
这个答案有帮助吗?
得分 1
添加一条评论
Is the wonky piece one of the white plastic mechanisms? With like a wheel or with a spring attached? If so or not it might be that u lost a spring that forces the wonky piece back into place when u eject. The ps3 taking in disc's is pretty easy it's getting them back or getting them to spin right that's hard. U have to make sure that everything is n the right place right position and coinciding with the other pieces when u put it back together they should all be in one position closed with no disc in but when u put it back together u have to open up everything as if it were taking a diac so everything falls into place correctly hope this helps
Update
Oh also it could have been when u used the screwdriver to manually turn everything and eject the disc. Try that again but turn it the opposite direction of when u did it last then if that doesn't work try back the other way. But before u do either of those be sure that all pieces are where they're are supposed to be and to really know that u have to watch it work with the top off to really see. When u manually turned it that makes all the gears catch and that either lifts or lowers ur disc reader so one of ur parts is not doing what it's supposed to or its not correctly in place.
这个答案有帮助吗?
得分 0
添加一条评论
You need to get a new blue ray drive.
这个答案有帮助吗?
得分 0
添加一条评论
My problem is right were the eject button is on the slim if u took the ps3 apart u would see a white piece that will come up when u put a disc in or go down when the disc is coming out well it wo5 t do none of that for some reason it won't take my disc or eject it can anyone help me figure this out please
这个答案有帮助吗?
得分 0
添加一条评论
I found a solution I haven't seen anywhere.
None of the answers I found online helped me, including manual eject, checking springs, gears, or other parts, and even removing the felt.
After observing the drive in action without the metal cover on it, I realized that the disk was catching before it could contact the little back rollers that spin and "grab" it. There is a little white runner or tab, for lack of a better term, by the black roller had been slightly worn into by the disk over the years. The disk would catch on it and not make contact with the rollers, which are supposed to eject it. I cut the little groove it had made back smooth so the disk glides over it into the roller, and now it works perfectly. (The roller im talking about is circled, and the white tab is what the arrow is pointing to)
To check if you have this same problem, remove the metal plate covering the drive, then insert a disk partway (with the console off) and use the manual eject with a screwdriver to slowly finish inserting it. When the gear hits the stop/end, slowly rotate the screwdriver the other way and observe where that black roller is. If the disk doesn't eventually slot into it, then your drive might have done what mine did.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 13
过去 30 天: 82
总计 12,904
