跳转到主内容
苹果 iPhone 5s 于2013年9月10日公布。该设备的维修与以前的型号相似,需要螺丝刀和撬棒。可使用GSM或CDMA / 16、32或64 GB。颜色有银色、金色和太空灰。
3530 个问题 查看全部
iPhone 5s, error 40 after screen replacement.
I just changed the screen on my iPhone 5s. After I booted up I had no power. I plugged it into my PC and then opened iTunes. iTunes tells me that I needs to restore the phone, so naturally I do and when it gets to the "waiting for iPhone" it then quickly gives me the error 40 code. I don't know what to do, the screen also doesn't display anything properly, and by that I mean the apple logo, because its the only thing I get it to display(the phone turns on when this happens only when iTunes gets into the "waiting for iPhone" part).
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
添加一条评论
4个答案
最有帮助的答案
Here is a screenshot:
I was very excited to get a hand-down iPhone 5s, then now I am very upset to find it kaput. I believe prfc: it makes sense that this error, "The iPhone" "could not be restored. An unknown error occurred (40).", indicates that flash memory is detaching / separating from mainboard. Boot code in ROM initiates backlight, screen is fully blank black. iTunes can attempt to install operating system to flash memory, is not successful (error 40) because memory package is becoming disconnected. How disheartening.
As of 2017-02-07, Apple (United States) repair price of iPhone 5s is $ 269. I am not capable of reflowing anything nearly as high-tech as iPhone. (I am a beginner solderer.) Maybe after next new iPhone is released, price for pre-used logic boards will be lower, and maybe iFixit will have them in stock.
Addition 2017-02-12: I thought "Not much to lose, go ahead and toast it!", spent last few hours trying to reflow my 5S logic board. I did not do it "the right way" by removing shield. I just blew it with hot air, shield still on, over where NAND package can be found. This was exercise was futile: iPhone still is useless, iTunes still results error 40. Here is a snapshot of iPhone screen, with its empty progress bar:
这个答案有帮助吗?
得分 5
2条评论:
I have exactly the same problem, my is a gold 64gb ATT one. hope you can help me out, thanks
完成的
hi sir i am mobile also same error 40 wats a solution
完成的
添加一条评论
Check my video it's power ic and nand flash problems... :)
https://www.youtube.com/watch?v=RYeuMzhN...
这个答案有帮助吗?
得分 4
1条评论:
Hi...
Thanks for the video! My iPhone 5s showed no image (only backlight) when turned on and iTunes reported "error 40". I followed the procedure from your video and now when I turn on the phone it shows the iTunes icon. Nevertheless, iTunes doesn't recognise the phone when I plug it in. Do you have any suggestions?
Thanks!
完成的
添加一条评论
its a common problem and even apple couldnt fix it. I kept trying and finally figured it out. do you still have the phone ? please tell me what carrier, gb and color is the phone ?
这个答案有帮助吗?
得分 3
4条评论:
完成的
i have iphone 5s with error 40
完成的
my iphone 5s is at&t,16gb,and silver color
完成的
Change nand set done
完成的
添加一条评论
Well I too had the same problem.... here is a temporary solution but still you will need to change your battery. You need to connect your iPhone 5s to iTunes in your Mac or PC and try restoring it for multiple times. I had done the same for almost 4-5 days and then it turned on. And keep it on charging at most times. Though it will turn on but still you will need to change your battery. ☺️''
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
wudupkid 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 6
过去 30 天: 20
总计 20,272
