跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Screen/digitizer/LCD replaced Digitizer and home button aren't working
I replaced the glass and digitizer on an ipad mini. Upon removing the LCD it cracked so it was replaced as well. No that everything is reassembled (not glued) the home button and the digitizer aren't registering. All contact prongs are in place and check out. I'm about to replace it with the only glass/digitizer to double check logic board function but has anybody had this issue before?
Installed old/cracked screen/digitizer and everything functions. Deduced that the new digitizer isn't functioning properly.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
This is going to be damage to the digitizer fpc socket. Pull the digitizer gently out of the socket. Look in the socket. If you see any gold pins missing, that is the culprit. It is extremely common.
It can be replaced as a mail in board-level repair
Jessa
这个答案有帮助吗?
得分 0
2条评论:
Where do I mail it in to?
完成的
Carissa--click my profile to find your way to my business website. You can create a ticket and get your repair started from my mail in page
完成的
添加一条评论
添加你的答案
Garrett 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 10
总计 307
