跳转到主内容
Released December 3, 1994 in Japan and September 9, 1995 in North America. Models SCPH-100x, SCPH-3000, SCPH-3500, SCPH-500x, SCPH-550x, SCPH-700x, SCPH-750x, and SCPH-900x.
73 个问题 查看全部
SCPH-1001, no video/audio, green light is on
No video or audio. The laser assembly moves but the spindle motor won't spin. No obvious signs of spillage or overheating.
Where do I start? I'm repairing this for fun so time is of no issue. Is there even a schematic floating around for these?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
1) it might be a CPU issue, or the traces/solder joints may be broken. If not, then the power supply might not be outputting on some of the PSU-Motherboard connector's pins. The condition of the boards is also imminent to the functionality of them; Corrosion, trace damage, general time wear on the components, these can (and will) affect the functionality of the PlayStation.
2) Being a professional in the field, I'd highly suggest starting with the Power Supply Board, and go from there. Just something experience has taught me. As for schematics, you can get your hands on the service manual, which has everything you will need and more. However, actually obtaining a pdf of it is difficult, since Sony forbade the reproduction and public distribution of it to non-affiliates and unlicensed personnel. But if you search around, you can probably find it in some shady or foreign website without use of the Dark Web. I found a decent Pdf of it, but I can't link you to it since I'm writing this on my PS4 and don't have the ability to copy or paste. Search 'SCPH-(your model) Service Manual' on Google — without parenthesis, of course — and see where that gets you.
Best of luck.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bob 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 8
过去 30 天: 21
总计 631
