跳转到主内容
This multimedia-geared dv6 comes with a 15.6-inch display, a built-in stereo, and weighs just under 7lbs. It is simple to disassemble- only a small screwdriver and a paper clip are required.
4 个问题 查看全部
问题已关闭
Internet Connection Problems with Updates
After each of the past couple of updates, I lose internet capabilities. It shows that I am "connected" to the wifi router (and I am literally right next to it) but it won't give me an internet connection! I end up having to do a system restore to get things back. What do I need to check to see what the problem is and how do I keep this from happening??
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
You should go ask Microsoft for this matter .When the update runs it might have detected a newer version of your wifi and installed that on computer.
Do a Factory Reset to fix it then turn automatic update OFF. If you really really need to keep your PC up to the latest update (I really dont understand what help can those updates give you) then leave it on, but every time it update go and have a look at the update files uncheck everything related to WIFI, MODEM, LAN, INTERNET.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 111
