跳转到主内容
Life Play, by Blu, released in April 2013, also known as BLU100a or BLU100i, depending on the 3G frequencies it gets.
18 个问题 查看全部
My blue life play stopped charging.
I dropped my phone and the top right has a small crack. then couple days later I tried charging it and it wouldn't charge. and then I took it to the store where I bought the phone and asked them why my phone won't charge. they took a look at it and told me my charging port broke. then they gave me a address and phone number for the onsite cell repair in Houston, TX. I tried calling them but I didn't get an answer. what do I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Had the same problem with my BLU Life Play X, and I didnt once drop it or get water on it. The charging port simply quit working. I think this is a recurring problem with BLU manufactured phones, I'm on my second phone from them within the past year and they simply do not last longer than 6 months (based off my own experience.) What I was able to do as a temporary fix was to bend the USB charging part (The silver part that plugs into the phone)just enough to get it to charge. Eventually I had to lean it against something and put weight on it to get a response from the phone. It doesnt help much but will charge your phone temporarily enough to save your pictures and videos before you need a replacement.
这个答案有帮助吗?
得分 1
4条评论:
will it still work if the charging port came off?
完成的
I'm not sure--I dont think so, but you can give it a try.
完成的
nvm, I tried it, it didn't work, i'll just have to wait to fix it, do you know a place where I can send my phone to so they can fix it?
完成的
Nowhere that I know of, unless you maybe take to Best Buy or a similar store?
完成的
添加一条评论
添加你的答案
brandon fleming 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 7
总计 2,425
