跳转到主内容
Toy quadcopter with camera, controlled over Wifi by smartphone.
23 个问题 查看全部
Trouble shooting a loose wire on my 2.0
Typical signs of a loose wire any rough movement of the drone and I loose the LEDs on the bottom and get them right back. I did some testing right after take of with hard spins and flips normally causing the problem and for it to crash. Any ideas on where to start or a common problem I can't find would be great.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Well I am not an expert on the topic but if the wires connect on the mother board this should help you gain access to the motherboard to see if the cables are connected and the power supply. Maybe you have a short Mother Board Access
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Brian 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 8
总计 398
