跳转到主内容
13" aluminum unibody, 2.0 or 2.4 GHz Core 2 Duo processor.
574 个问题 查看全部
new fan now spins 100% speed
Hi there I just ordered a new cooling fan and after installation it only spins at 100% speed which is kinda annoying, especially because its a blower style fan and makes alot of noise. Just wondering if there is something i could have done wrong or if the fan itself could be the issue
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Missing a wire/pin, or not plugged in all the way. Probably borked fan.
Why did you replace it to begin with?
Does the laptop run slow? It could be a sensor issue.
这个答案有帮助吗?
得分 1
1条评论:
It is a borked fan. I replaced it because the stock one was on it last leg when it spun up it would make bearing noise plus I have been kinda fixing it up alitle, pulled it apart cleaned it, reapplied thermal paste, new RAM, and went to SSD. But I did all that before I ordered the fan and everything was working like it should. And I have not experienced any slow down, and the app I downloaded to read cpu temps it reading 40-41c which is where it was before but fan speed reads 0rpm.
完成的
添加一条评论
添加你的答案
mtbskilz 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 75
