跳转到主内容
Apple发布于2012年9月12日的第六代iPhone,维修时与前代型号一样,需要螺丝刀和撬棒。iPhone 5以多种版本销售:通讯制式有GSM/CDMA;存储容量有16/32/64G;颜色有黑/白。
2522 个问题 查看全部
问题已关闭
Phones restarting every couple of minutes
I've just replaced the rear housing on my iphone 5 I punctured the battery by accident and now my phone keeps restarting before the battery percent goes down does the same when charging I also didn't put the screens bracket back on over the cables on the logic board is this a problem? And will the battery be causing this
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi Michael,
From the sound of it, if you punctured the battery and also left off a bracket, there are probably other things that you may have inadvertently done to cause this but are not aware of yourself. First step would be to replace the punctured battery because, well, you punctured it. Next, you definitely want to put the bracket on and the screws in the correct and proper order. I am not saying that these steps will solve your issue but before we diagnose the device, it would be good to have it as close to square one as possible. Therefore, battery and bracket, then we can go from there. Good luck!
这个答案有帮助吗?
得分 1
1条评论:
What does that bracket actually do as I didn't think it would have much effect
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 105
