跳转到主内容
Samsung's 5th-generation Android-based Galaxy smartphone was released April 11, 2014. Improvements to the phone include a fingerprint scanner, updated camera, larger display, and water resistance. It is available in four different colors; black, blue, white, and copper.
Loudspeaker does not work after screen replacement
A customer came in with a Galaxy S5 that he had replaced the display assembly on himself. Overall, it actually looked like he did a fine job of it. However he said that after he changed the screen, the loudspeaker worked once, then when he turned the phone off and back on it stopped working and has refused to ever since. He still gets sound out of the headphone jack and over Bluetooth connection. He has tried everything (and I do mean everything, I asked) short of replacing the actual speaker unit with no luck. If a new loudspeaker does not solve this problem, what could be going on here?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
3个答案
Did you ever figure this out?
这个答案有帮助吗?
得分 0
1条评论:
Sadly no...I have not seen the customer again either.
完成的
添加一条评论
i have a phone in with this issue
这个答案有帮助吗?
得分 0
添加一条评论
I have a phone with this issue too replaced speaker and checked all pins and nothing
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
JonMark 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 6
总计 1,590
