跳转到主内容
This is a guide for the LG Optimus G Pro Phone. It was released February 2013, and can easily be identified by its Model Number: E980.
25 个问题 查看全部
Why is by front camera not working?
My front camera refuse to work. Every time itry lunching it, it freeze for a minute and says" camera unexpectedly stop, restart " even apps like snapchat don't work. But the back camera is working greay. Why might be the reason and how can I fix it?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
最有帮助的答案
Hi rStephen,
It may be due to a software glitch, but most likely it is going to be a hardware issue. I say most likely because it is usually never as easy as resetting your device. The front camera can be found pretty inexpensively, so you can test this fix for most likely under $10. If all else fails, factory reset might help. Good luck!
这个答案有帮助吗?
得分 3
添加一条评论
添加你的答案
rStephen 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 3
过去 30 天: 4
总计 1,450
