跳转到主内容
加入维修社区 - 创建账户
苹果公司于2013,11,1发售了更薄,更强的iPad Air ,有太空灰和白色,配置了 定制的A7处理器,并有16, 32, 64, 和 128 GB可选。
My ipad air say ipad is disabled connect to itunes
my ipad is disabled how can i fix it
回答此问题 我也有这个问题
这是一个好问题吗?
得分 33
4条评论
my pad is disabled ..how can i connect it to i tunes?
完成的
need a little more information such as how did it get locked? Incorrect password? etc
完成的
was new and grandkids set up stup and played with and cant remember anything so disabled
完成的
I forgot my pass word, tried to enter other pass words to many times.
完成的
添加一条评论
8个答案
最有帮助的答案
First thing to rule out--time/date error from the battery going dead. Connect to WiFi--usually by going within range of a WiFi source that the iPad has connected to before so it will connect automatically. Hard reset to restart. (Power and home buttons for 10 seconds)
If not solved, then you'll have to erase the iPad and start over--all data will be lost. You can force the iPad to boot into recovery mode by doing a hard reset (as above) but this time leave the home button connected and the iPad connected via usb to the computer.
This will prompt iTunes to ask if you'd like to restore the iPad--i.e. erase and start over.
jessa
这个答案有帮助吗?
得分 6
1条评论:
thank you so much, your answer is really helpful, it solved my problem too.
THANK YOU :)
完成的
添加一条评论
Ipad locked up for no reason at all
这个答案有帮助吗?
得分 2
1条评论:
I forget 4 code .and lock
完成的
添加一条评论
Turn off the device: Press and hold the Sleep/Wake button for a few seconds until the red slider appears, then slide the slider. Wait for the device to shut down. While pressing and holding the Home button, reconnect the USB cable to the device. The device should turn on
这个答案有帮助吗?
得分 2
添加一条评论
My iPad can't connect to iTunes ' how I can connect to my iTunes?
这个答案有帮助吗?
得分 1
1条评论:
How can I connect to my iTunes with my iPad?
完成的
添加一条评论
I am deaf in computer ,
这个答案有帮助吗?
得分 1
添加一条评论
my ipad diabled to connect itunes
这个答案有帮助吗?
得分 0
添加一条评论
attention save this password in open ipad connect to itunes
这个答案有帮助吗?
得分 0
添加一条评论
Put the iPad Air into recovery mode and then connect to iTunes to restore it. Or consider a tool called Joyoshare iPasscode Unlocker to help you. These two methods are frequently used in terms of unlocking a disabled iOS device.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Mabior 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 30
总计 10,691
