MIP bluetooth won't discover
Trying to use bluetooth with my iphone 6 and it never FINDS the MIP---just says discovering over and over...Thoughts?
Try switching Bluetooth on or off in the Settings and try pressing the refresh button in the top right. As mooka1 said, try tapping on the auto-connect screen.
这个答案有帮助吗?
I have an LG k10 and I am haveing the same pobelm
if its stuck not the search for mip screen (has the mips jumping up and down on it) tap the screen and you should go through to another screen that allows u to pick a mip.
hope this helps.
这个答案有帮助吗?
The MIP robot is no longer discovered with the Android 8.0 (Oreo) update (bluetooth issue). Already reported to Google.
这个答案有帮助吗?
This is correct I have android 8.0 and I was able to connect the mip to the app, but after I had to change the batteries the mip isnt showing up on my phone again. Very frustrating.
If your mip doesnt turn on with new batteries then there might be a loose wire. I had TO takes the screws out of his back and mess with the wires. There should be a black and red wire (thicker than the other wires) have masking tape on the end of the wires. Tape the wires back to there circuit board and it should turn on
I Can't connect my Mip to my phone. It says I need a passkey but it never said that before. Earlier it connected flawlesly. Please help me find a fix.
这个答案有帮助吗?
Yeah me too can someone help . What is the pin?
Try switching Bluetooth off and then on a couple of times. If not the try charging the MIP.
这个答案有帮助吗?
It worked just fine on android 5 untill i put new batteries into mip then its not showing on the app it shows the mip in the Bluetooth menu but it needs a
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 32
过去 30 天: 86
总计 31,167
6条评论
How to pair it and is deos'nt register
由 XxAlthanixX 完成的
Having same issue. Tried replacing batteries, uninstalling/reinstalling app. No success. Entered a ticket on WowWee's website, but no answer yet. Will post when they do. Please update if you find a resolution.
由 AAJones 完成的
We had the same problem. We ended up exchanging it for a new one. We knew something was not right when it wouldn't connect to any devices including an iPhone 6. As soon as we turned on the new one - it connected to our son's nexus 7. Looks like the Bluetooth was broken in the original mip.
由 jeana 完成的
Please can someone help me! I need the password for the bluetooth when trying to connect? Any ideas as to what it could be and where i could find it
Thanks
由 Rashida Vagh 完成的
does bluetooth on? if not do this scroll down
由 Jelani Simone 完成的
显示更多的1条评论
