跳转到主内容
The Samsung Galaxy S II is a smartphone designed, developed, and marketed by Samsung Electronics with Android 2.3 "Gingerbread."
My samsung s2 is not turning on only logo keeps flashing
My samsung s2 got dead n is not turning on after charging only logo keeps flashing
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
my samsung s2 is not turning on
完成的
添加一条评论
1个答案
最有帮助的答案
Have you tried doing a hard reset to restore the phone back to factory settings?
The procedure does and will delete all files and downloads that are on your phone.
How to do a factory reset:
1) Turn the phone off. If you can't, remove and reinstall the battery
2) With the phone still turned off, hold down the Power button+Volume up+Menu buttons at the same time for about 10 seconds.
3) Scroll down and select 'Wipe Data/Factory Reset'.
4) Select 'Yes – Delete All User Data'.
5) Select 'Reboot System Now'.
这个答案有帮助吗?
得分 2
1条评论:
this method is not working to reset my samsung gallaxy s2.
there any other way using hardware support
完成的
添加一条评论
添加你的答案
Noureen Farooq 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,709
