跳转到主内容
MacBook, MacBook Pro, 和 MacBook Air 交流电 电源适配器。
65 个问题 查看全部
Replacing a Magsafe "L" connector with a "T" connector
Hello All,
I own a late-2008 13" Macbook Unibody. I tried to replace the "L" connector of the Magsafe charger with a "T" connector following the instructions in one of the step-by-step guides in IFixIt but the result was not successful. Even when not connected to the Macbook, the light on one side of the connector remains bright green all the time while the light on the the other side is a faint green. When I connect it to the macbook the battery does not seem to charge and does not power up.
Any ideas?
Thank you in advance
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
Best to just replace the compete AC power adapter Vs trying to fix the MagSafe connector. Most of the time the splice breaks down and the. Causes other problems.
这个答案有帮助吗?
得分 2
添加一条评论
From your description, I guess you have a defective replacement MagSafe connector. In a proper working MagSafe connector, indicator lights are OFF while not connected to MacBook.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Dimitris 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 1
总计 492
