Why wont my tablet power on?
Tablet pluged into charger but still wont power on.
Yes, I have tried that many of times but it still did not work, but I believe it has something to do with the inside of it or either the charger port.
这个答案有帮助吗?
I have tried all of that even have brought a new charger and tablet still not working.
这个答案有帮助吗?
try to leave your tablet plugged in for the day making sure the chrging coard is plugged into the wall corectly and that its connected to the tablet all of the way i had the same problem with mine
这个答案有帮助吗?
When I plug my tablet up it won't do anything and it's not even a year old since I bought it
这个答案有帮助吗?
I want to be able to use my tablet again or does it still have a warranty
I need to know if I still have factory warranty on my tablet
过去的24小时: 0
过去的7天: 1
过去的30天: 3
总计 1,651
Have you tried using a different charger or using a different outlet?
由 Katherine 完成的
yes and sometimes it starts, but goes off after 10 seconds
由 PAUL WILSON 完成的
On my old Tab 2, if I leave the power jack plugged in it seems to cause a malfunction with the screen so I unplug it when using it, see if that is the case, to eliminate possiblities.
由 Mark Hayward 完成的
