跳转到主内容
加入维修社区 - 创建账户
iPod Classic 第六代。机型型号 A1238,80、120 或 160 GB 机械硬盘,黑色或银色金属前面板。
Why is my iPod stuck on the "HP dectect test" screen?
I was following ifixit steps to check the functionality of the hold button (diagnostic). The hold button is working fine (0 and 1). But now my screen is stuck on HP Detect : 0. It says press menu to continue, but when I press menu nothing happens. I have also tried pressing menu twice and several other combinations...
回答此问题 我也有这个问题
这是一个好问题吗?
得分 11
1条评论
—me to. have no idea why. it reboots fine -wasn't doing this a week ago.
完成的
添加一条评论
6个答案
最有帮助的答案
Plug in the headphones (HP).
这个答案有帮助吗?
得分 7
2条评论:
...........Hmmmmmmmn? Something about hindsight, and 20x20 eyesight....?!
Thanks!
完成的
so i should put my HP laptop away ?
完成的
添加一条评论
need to unplug it and then push MENU
这个答案有帮助吗?
得分 1
添加一条评论
i plugged the earphones. it says now hp detect : 1 menu to continue. i pressed menu but it does not continue.. can you please help?
any clue please e mail me at bernard_khoury@hotmail.com
这个答案有帮助吗?
得分 0
4条评论:
just take out the headphones and press the menu button then BINGO!!!
完成的
Now it says 'Accessories Test'
FW_DETECT = 0
USB_DETECT = 1
Please plug FW
What's this mean????
完成的
Firewire (FW) connection vs USB connection:
https://discussions.apple.com/thread/275...
完成的
Turn off hold button
完成的
添加一条评论
If it's not continuing, it didn't pass the headphone (HP) test. Ipods have a little detector that stops the ipod if a headphone isn't detected; it'll pause the song if the headphone jack is removed.
You might want to disassemble it and replace the headphone jack. If that doesn't work, it's probably a bad board.
这个答案有帮助吗?
得分 0
1条评论:
after plugging it in, unplug it, then it should continue
完成的
添加一条评论
I got mine to go to the next stage by clicking the hold switch on and then off.
这个答案有帮助吗?
得分 0
1条评论:
Now it's stuck on FW DETECT : 0
There's no Firewire to plug in, so I can't test this.
完成的
添加一条评论
Hello there. I have tried out a solution you your little problem here which was posted by Chi. You see, (HP) is abbreviated for Headphones, which is dumb but oh well, and it worked when my Headphones were plugged in and then unplugged.
这个答案有帮助吗?
得分 0
1条评论:
didn't work for me.
完成的
添加一条评论
添加你的答案
alysont1 将永远感激不已
浏览统计数据:
过去 24 小时: 5
过去 7 天: 16
过去 30 天: 131
总计 32,986
