跳转到主内容
Repair information for the Gaggia Classic Espresso Machine.
20 个问题 查看全部
Espresso Steamer leak repair on Gaggia Classic
The milk steamer leaks when machine is on.
See Item on the right:
https://d3nevzfk7ii3be.cloudfront.net/ig...
It has a tiny washer inside it. I replaced that washer to stop the steamer leaking water and steam at the screw on the join at the washer in the image.
What else could be causing the leak?
I note one part of this Steamer is brass the other chromed material... heating and expanding at different rates?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
最有帮助的答案
The steam valve ("tap") in this machine is a single piece assembly which has a brass-on-brass seal; it can not be disassembled and once it starts to leak the entire valve must be replaced.
这个答案有帮助吗?
得分 1
添加一条评论
Hi, Take the complete tap house out of the machine, take the tap apart and descale the housing and the parts you find in the tap. In the tap body; check if the seat of the washer is not damaged. crease it and put it back together. You can get machine descaler in the shop (not machine cleaner, but descaler) good luck.
这个答案有帮助吗?
得分 0
1条评论:
The tap in this machine can not be disassembled.
完成的
添加一条评论
no vapor in gaggia baby classica
这个答案有帮助吗?
得分 0
1条评论:
only ligh green no ligh coffee no ligh vapor
完成的
添加一条评论
添加你的答案
Kevin Sharp 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 12
总计 2,192
