跳转到主内容
Bluetooth wireless headsets used to connect to phones and computers.
Where can I get a new Sennheiser VMX100 Bluetooth headset battery?
I have a Sennheiser VMX100 Bluetooth headset that went through a wash cycle in the laundry. I suspect the battery was shorted out as it will not charge now. The charging light will come on when plugged into the charging adapter but will not change from red to blue indicating the end of the charging cycle. So I would like to try replacing the battery or get the unit refurbished. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hi, did you replace your battery? if so where did you get a new one. THKS
完成的
添加一条评论
7个答案
最有帮助的答案
Hello, thought I would post an answer, as I have a Sennheiser VMX100 too.
You can contact Mina Zhao, via AliExpress. She sells the 522020 model for U$3.40 plus U$4.42 postage. You can buy 1-piece or bulk. Here is the link ... http://www.aliexpress.com/item/L044-3-7V... (03 FEB 2013)
Also, Green Energy Tek sell the original. Their link is ... http://www.greenergytek.com/info-3970554... (03 FEB 2013).
You can contact them here:
Tel: (86)-755-2937 1695 (Daniel)
Fax: (86)-755-2937 1615
info@greenergytek.com
You should not be paying more than U$12.00 for this item, they can supply 1,500 per day.
Update (10/02/2013):
eBay (http://www.ebay.com/itm/Li-Po-Battery-3-...)
Today, 19/02/2013; I can say that the VMX-100 works 100% once again. I purchased a Li-Po Battery 3.7V 140mAh LiPo for Micro Helicopters from walkera-esky [[http://myworld.ebay.com.au/walkera-esky]]. The battery will fit and only costs U$5.99 + U$3.75 in postage. It comes fully charged, so simply unsolder the 2x RED and BLACK wires and resolder the new battery in place - and you're DONE!
So if you have a Sennheiser VMX-100 and you need to replace your battery. You can buy HERE:
Walkera-Esky
351 Oak Pl
Ste C Brea, CA 928214123
Update
Hello,
Firstly, I removed the casing, which means that the single screw under the sticker at the bottom of the VMX-100 had to be removed. Secondly, I took a photo with my iPhone of the connection, so that I did not reverse the polarity and reconnect the new battery incorrectly. Thereafter, I removed the battery by unsoldering the RED and BLACK wires that are connected to the motherboard/mainboard. Lastly, I re-soldered the new battery, according to the photograph I previously shot.
The VMX-100 immediately springs back to life, as the battery has residual charge. One can now use the VMX-100. I chose to fully charge the Lion battery and since I last made this post, that is to say from 19/02/2013 to today, 01/03/22013; the VMX-100 is still on that initial charge.
这个答案有帮助吗?
得分 2
添加一条评论
I also have a VMX100 which did not get laundered but has the same symptoms.
The battery spec 3.7 volts but after overnight charging it only has 2.8.
Dont know if it is the battery or the charging circuit
Watch this space
这个答案有帮助吗?
得分 1
添加一条评论
The battery is supposed to be a lithium-polymer battery. It is flat, in a metal case, a rectangle ~1/2" x ~3/4" in size. On one side it is marked:
+ ATL
681622
- 3.7V
On the other side, there is an Underwriters sticker and these numbers:
940
7275
02795
There is also what looks like a 2D bar code.
这个答案有帮助吗?
得分 0
添加一条评论
ATL Active Model 681622
Capacity Impedance   Thickness Width  Length
(min) (max) (max) (max) (max)
140 mAh 300 mOhm 6.5 mm 16.5 mm 22.0 mm
maybe a rc helicopter polymer battery with same Capacity and dimensions could be ok
这个答案有帮助吗?
得分 0
添加一条评论
Tmart.com above you can buy which products are good.I often buy above any need something.
这个答案有帮助吗?
得分 0
添加一条评论
I have a 'new one' I've used it only a few times. Let me know if you are interested in purchasing it.
这个答案有帮助吗?
得分 0
添加一条评论
Why when talking is keep on cutting sound and signal too.? Adopter is how many watts
Thank
这个答案有帮助吗?
得分 0
1条评论:
Why my vmx100 is keep on cutting signal? And how many is voltage on adaptor?
完成的
添加一条评论
添加你的答案
Perry Godwin 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 8
过去 30 天: 35
总计 7,280
