跳转到主内容
Repair guides and troubleshooting for HP Pavilion dv7 laptops, manufactured by Hewlett-Packard starting in 2008, and featuring a 17.3" diagonal display.
137 个问题 查看全部
Broke the lock, that connects the keyboard to the motherboard.
I was trying to open up my laptop a while back and when I was putting everything back together I broke the lock that connects the keyboard to the motherboard. Is there anyway for me to reconnect my keyboard?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
What you're looking for is called a "retaining clip", though I'm seeing them more often called a "cable clip". These aren't usually considered "replaceable" parts, as they're so fragile. However, I have seen various ones on eBay. The dv7 is common enough, you should be able to find one (I struck out). I warn you, however, that you run a pretty big chance of breaking the replacement as well while attempting installation. It's probably worth it to get the system running again, I just wanted to make sure you understand the risk.
Good luck and make sure you let us know how it turns out!
这个答案有帮助吗?
得分 2
2条评论:
Do know about the cable clip for connection the mouse to the motherboard on a hp 8560w elitebook.. and the clip for connecting the buttons on the to the mother board?
完成的
While the answer I gave was in response to someone asking about a specific model series, the answer applies to all laptops (and many/most mobile devices). Just search "cable clip" or "retaining clip" along with your specific make/model, or better yet, the part number of the board to which the connector itself is soldered. I haven't looked lately, so I don't know how much luck you'd have, but it's worth a shot. All warnings and cautions also still apply.
完成的
添加一条评论
添加你的答案
Jose 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 3
总计 1,106
