跳转到主内容
The Samsung Galaxy S3 is a multi-touch, slate-format smartphone with eye-tracking ability, increased storage, and a wireless charging option.
459 个问题 查看全部
How to diagnose dead board of Galaxy SIII?
I was having problem with my USB charging connector and changed it, but now the phone is completely dead and does not power on nor does it charge or show anything on screen. The connector is fixed properly but still nothing works seems the board is dead. How to diagnose the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
Hi,
First check the battery voltage with a multimeter. If the battery is less then 3.8V, try to charge it externally.
When you have a charged battery, try to switch-on it. If the phone switch on normally then you have a problem with the charging.
If the phone can't switch-on, try to enter the phone into Android System Recovery menu or in Download mode (Volume Up+Home+Power or Volume Down+Home+Power). If you can enter this modes, maybe the problem is into the SW. You can reset it from the Android Recovery menu or to reinstall the firmware from the download mode. The battery must be at last 80% charged!!!
If no, try to connect the phone to the PC by holding the volume down button.
If the battery is charged and if the Windows can't recognize connected device, then you have a hardware problem.
Regards.
P.S. You can buy a JIG dongle for entering Download mode for Samsung Galaxy S3 or you can find easy in the internet how to make it by himself.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Huzefa Darolywala 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 1,261
