跳转到主内容
加入维修社区 - 创建账户
作为任天堂 Game Boy Advance 的一款升级产品,Game Boy Advance SP 于 2004 年 3 月 23 日在北美地区发布,它采用了方形机身结构和翻盖式设计。
Charge light goes on then off
I plug in my charger and the charging light flashes on for about a second before it turns off. I'm pretty sure it's not the charger because it works with another GBA SP, though that one is a slightly different model.
The model that isn't working is the newer one, with the brighter screen. I don't know if that has anything to do with the problem. It's also not the battery because it works in my other GBA SP, the older model.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 21
10条评论
I have the same problem. Due to my lack of soldering skills, I may not have seen the source of the problem. I have swapped batteries, bought a new charger, all to no luck whatsoever. I hope somebody on this site can put a soldering tutorial, as I have an iron and I don't know where to put anything.
完成的
You nead to replace the battery
完成的
I'm having the same problem, but I'm fairly certain it's due to a warped charging port.
完成的
I am now having this problem. Gameboy good as of a few months ago, now with 2 different batteries, won't charge, so sorry Codie. Something seems to be broken with its charging circuit. One of the batteries are completely dead, the other has enough power to make the system function, but the low battery red light comes on. It seems simply to not be able to charge any battery. If anyone has any insight to fix this or any recourse, response would be appreciated. Otherwise, I will probably ebay it and let someone with the experience refurbish it.
完成的
I got a new GameBoy Advance SP and the light goes on for a second and a half and then turns off. I tried the car charger and that worked for 3 seconds before doing the same thing. Do I need a new internal battery or is there a way to fix the charging port or something?
完成的
显示更多的5条评论
添加一条评论
24个答案
最有帮助的答案
Hey Daniel,
Make sure the charger you are using is the proper voltage to charge the device. If it's too little, it will not take a charge, you may see a little light like you said.
The charge cable may not be the problem, it may be the port you are plugging the cable in to. This port is soldered on to the motherboard of the Gameboy, and if it has become loose, you will not be able to charge it with ANY charger. If you have basic soldering skills, this is not a difficult repair, if you do not have an electronic repair background, I would advise selling it for parts, and purchasing another one.
Have a good one, sir. :)
这个答案有帮助吗?
得分 12
3条评论:
Will it matter if my charger, since my sp's battery has a "ags 003: matter if my charger says "ags 002" on it?
完成的
It was the charging BOX that I was using. Thank you so much!!
完成的
Mine ended up being the battery. If it’s completely dead, the gameboy will try and charge it but not detect a usable battery, so the light will come on for a moment then turn off
完成的
添加一条评论
Bought a few GBA SP’s in a lot a few weeks back, I had this issue with 2 of them. The orange charge-light would come on briefly for about 1 second then turn off.
Over the last few years I’ve heard everything from “bridge/replace the F1 fuse” to “replace the charging port”, but I think I can safely safe 9 times out of 10 it’s just the battery that’s dead. I just finished fixing these 2 GBA’s and both of them work fine now that I put in good replacement batteries. The charge light stays on while charging.
Advice;
- Check the charge port contacts to make sure they’re clean and there’s no bent pins. If the power adapter charge-plug can’t touch the charge-port contacts of the GBA SP itself, it’s needs to be replaced. Sometimes if the connection is also loose you might need to “bend” the charging-cable while it’s plugged in to make full contact with the GBA SP’s charging port. If it still works then great, but you’ll probably need to replace it sooner or later if that’s the case. Give it a wiggle, see if that helps. That’ll tell you if it’s the charge port or something else on the board.
- Try a different charging cable.
- Check the connections of the GBA SP charge-port itself to the motherboard. Open it up and look. If it looks like the solder-points have cracked and they’re not making contact, use a soldering iron to lightly ‘touch-up’ the charge port contacts to the motherboard and re-melt the solder that’s available or add some solder, as well as touch up the 4 tiny legs of EM8 just below/near the charge-port itself. EM8 is a main power-regulator for the GBA SP boards from what I’ve figured out, sometimes if that has a bad contact it can disrupt the charging process too.
- Try putting in a new battery, or try with someone else’s battery first to see if their battery will work in your GBA SP. Then you’ll know for-sure that you just need a cheap battery replacement bought online.
New batteries are about 5-20$ depending where you buy them, I generally buy most of my little spare parts from Aliexpress. The shipping can be rough to wait for since most of the products are coming out of China, but the parts I get are generally good and work right. Out of 20 GBA SP batteries I bought in bulk for $1.38 (CAD) each, I had 2 that were a duds. It just happens when you buy something cheap in bulk, once in a while it ain’t gonna work right.
I’m not an expert, these are just nuggets of experience I’ve had in my years of fixing Gameboys, Gameboy colors, Gameboy Advance SP’s, and the odd DS/3DS. I do this as a hobby, so if anyone can provide a more clear response then please feel free to add more. Hope this helps!
这个答案有帮助吗?
得分 4
添加一条评论
try taking out the batteries and putting it back then charging it that worked for me
这个答案有帮助吗?
得分 3
3条评论:
Out of all of the posts this is the comment that saved me lol
完成的
This worked for me too. Took out the battery, cleaned the connectors and boom, works again
完成的
I took out the battery, put it back in, but it did the same momentary charge light flash, so I wiggled the battery around in place which I think finally gave it the connection it needed to charge it. Orange charge light is staying lit! 👍👍
完成的
添加一条评论
If it does that it means the battery is full :D I also didn't know that and thought it was broken but it isn't bad IT JUST MEANS THE BATTERY IS FULL
这个答案有帮助吗?
得分 2
3条评论:
You are not joking, thanks dude!
I almost broke my charger trying to figure out the problem thinking that my charger is faulty but then I kinda played for some minutes, plugged in, and it's charging!
Guys, I know how it feels, I felt like not using the game boy as if I finished up the charge, there would be no charger, but please try once playing for a while and then charging, I bet it works...
But anyways, if you screwed up the charger, here is a link. Get the cable for 4 dollars without shipment charges worldwide!!
https://m.banggood.com/1_2M-3_9ft-USB-Po...
完成的
That worked in my case too! I just fiddled with the charger and when I plugged it completely in,BOOM!It was charging
完成的
100% correct, after reading your comment, I googled and learned that when turned off these loose little to no battery so mine were fully charged. THANK YOU!!!
完成的
添加一条评论
I bought this from another seller and it worked before, but I tested it now and it does not want to charge up (the light indicator would show but then quickly disappear).
这个答案有帮助吗?
得分 1
2条评论:
This literally the same problem I have, post if you find a solution.
完成的
It's most likely already full of charge.
完成的
添加一条评论
Hey! I think I have an answer for most of you.
If the battery swap doesn’t works, open your GBA SP up and be assured that the screen ribbon cable is properly and fully plugged in the motherboard - and that the locks on both side of the ribbon port is properly pushed fully down (or up if it’s not plugged in a perpendicular position). Most of the time when I repair a GBA SP with that flickering thing going on, that’s what is happening.
Also, it sometimes can create a random restart on your GBA, so it’s kind of a sign that your GBA SP doesn’t receive properly the AC/Power from the battery to the screen.
这个答案有帮助吗?
得分 1
1条评论:
I stumbled across this comment and I think it might be the solution for a question I just posted that I thought was unrelated to this thread. Thank you!
完成的
添加一条评论
There is not enough public info about flat batteries..if a battery sits long enough and discharges on it's own it will go flat.
sometimes, specially with newer batteries and lithium, you have to get some juice in them to get them started charging normally.
I sometimes can do this by plugging and unplugging the charger many times then leaving it plugged in for a while and doing it again.
power tools will seem to have bad batteries after sitting a winter etc. they just need a jump start
这个答案有帮助吗?
得分 1
1条评论:
That's exactly what happened to my battery.
Revived it by several cycles of plugging-unplugging.
完成的
添加一条评论
This happened to me too. Luckily, my brother has another Gameboy advance SP that didn't work except for the battery. I swapped batteries and it appears to be working again.
这个答案有帮助吗?
得分 0
添加一条评论
This also happens when you fry your charger, a bit. I've opened up my charger and can see that the capacitor (if not mistaken) was loose. The solder has melted and loosen up the foot of the capacitor on the circuitry of the charger. I re-soldered it and good to go.
#This should affect all the GBA charged with this particular charger.
这个答案有帮助吗?
得分 0
添加一条评论
It's most likely the battery is full or the battery is completely dead and you have to swap it with another one
这个答案有帮助吗?
得分 0
添加一条评论
This happened to me but turns out the charging port on my gba sp was loose. I Discovered this when I shoved the charger when I was frustrated, this could be the problem so try to shove the charger in or something like that.
这个答案有帮助吗?
得分 0
添加一条评论
Either the battery is already charged or it’s the battery that is not working.
这个答案有帮助吗?
得分 0
添加一条评论
I have this problem today… jan 12, 2019.. the unit has been stored and forgotten for years, and of course the Battery is dead for sure… I used the charger I originally use on my Brother’s SP and it charged normally. for some reason mine is not.. why is that? I’m sure that i never had this problem before…
这个答案有帮助吗?
得分 0
添加一条评论
Hi, i seem to have a problem with my gameboy advance sp ags 101. The original battery was dead and i decided to swap it with another gba battery that is working. The thing is the little orange light thats indicating that the gameboy is charging is always oppen even if the gameboy is shut down or not plugged in. what can i do ? I fear that theres an issue with the mother board that just suck all the batteries.
这个答案有帮助吗?
得分 0
添加一条评论
So I like just had this issue. What I do is move the head piece of the charger around in the outlet until the light flashes orange indicating that it’s charged. Don’t know if this is safe or if it’s efficient but I guess it works.
这个答案有帮助吗?
得分 0
2条评论:
I was doing this as well and it was the only way to charge but then it stopped charging at all like 2 days ago I've had it back for about 5 days . I've been trying to figure out how I can fix it. Have you had any luck ?
完成的
I have the same issue! It used to be alright if I just jostled the charger around in the port for a while but now only charges if I constantly hold the charger towards the screen side. Did you ever figure out a fix? Should I just try to replace the whole charging port?
完成的
添加一条评论
had this problem and i just moved the charger while plugged in and eventually it worked lol
这个答案有帮助吗?
得分 0
添加一条评论
I fixed the issue I was having. It was the EM8 Chip on the board that controls the charging regulation. I replaced the whole port (not easy haha) but think all I needed to actually do was reflow the 4 pins on EM8 to the board with a soldering iron. Hopefully, this helps someone before they replace the whole charge port like I did!!
If you are deciding to replace the port makho on youtube has a good guide: https://www.youtube.com/watch?v=EnYxizt8...
这个答案有帮助吗?
得分 0
添加一条评论
I had this problem and I just got a q-tip with rubbing alcohol and cleaned up the charger and charging port, and then blew it out with a can of air, and it works fine now.
这个答案有帮助吗?
得分 0
添加一条评论
Just to put it out there. I had the same issue, turns out the screen’s ribbon cable was dislodged slightly causing the charge light to come on only for a second, reseating it fixed the issue for me. :)
这个答案有帮助吗?
得分 0
添加一条评论
Mine does the same thing but for 10-15 minutes
这个答案有帮助吗?
得分 0
1条评论:
Maybe there is just some dust in your power switch.
Easy fix. Open your GBA SP, Stick a soldering iron right on the pin on ONLY one side of the power switch and try to make them lift up.
Slowly tilt the metal piece up, and then remove the plastic button.
Now you can clean the little box with a small drop of IPA and a tooth brush. You'll see the bottom of that part become a bit more "shinny".
After that, put the plastic button back in place, tilt down the metal pin you lifted before down and on top of the switch, then add a little solder on the metal part you lifted so it hold tight like on your PCB just like before.
Sometimes, intermitent flickering lights are caused by a bit of dirt that can be remove on there (are on the PCB resistors).
完成的
添加一条评论
Ok so basically my first gba sp was working fine until it run out of battery and i din't had a charger. So I crafted something different in the battery slot ( i putted a different battery type) and it was working fine. Sice the battery was 3.7 volts i was thinking there would no be some overvoltage or burn insode the gba so it was going fine until one day i tryed to turn it on and it just burned inside. I remond that the right bottom of the gba becamed very hot inside when he died and that all. Today i have a charger and when i try to plug it whit a real gba sp battery this time, the red light turn on and off even if i swap the battery whit another gba sp battery on my first faulty gba sp. ( i have a new one and this time i take good care of it) so yeah i try to see where is the problem on the faulty gba sp now but idk where . what i know is that it maybe resieve to much current flow and it burned somewhere on the power path on the pcb. Sorry if its hard to read, my native language is french.
这个答案有帮助吗?
得分 0
添加一条评论
Sorry I’m late but this could mean that it’s fully charged. If it wont turn on try spamming the on/off switch decently fast until the green light comes on.
这个答案有帮助吗?
得分 0
添加一条评论
Just had the same issue with a battery that charged previously. I swapped it out for another and my system was able to consistently charge immediately.
这个答案有帮助吗?
得分 0
添加一条评论
I had the same problem. It was because of the battery. Not the charger, not the cable, not the GBA itself.
I solved it by plugging an unplugging the cable several times. I slowly noticed a little increase the time the orange light was on (not reaching a second). Then it stayed on and charged.
My guess is that the battery was in a deep-dichrge state and that refreshed the chargin protection and kickstarted it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Daniel 将永远感激不已
浏览统计数据:
过去 24 小时: 18
过去 7 天: 136
过去 30 天: 518
总计 125,381
