跳转到主内容
Repair your Dyson DC 14 vacuum cleaner with a part replacement guide.
The motor runs but it does not suck
I accidently hit one of my cats toys and the vacuum quite working. I unplug it and checked that the belt was not broken. The motor runs, but the vacuum will not suck. Is there a second belt somewhere inside that could be broken?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
Was the toy pulled into the vacuum? Could it have clogged the pipe between the brush and the canister?
完成的
As suggested by Andrew, check the little hose that is behind the beater brush. I have two DC14 vacs and both them have had the hose get plugged. Also, make sure the beater is running.
完成的
添加一条评论
1个答案
If your vacuum cleaner loses suction from its nozzle or hose, see the Dyson Ball Animal Has Loss Of Suction In Hose problem page for possible causes and solutions.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Gayle 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 20
总计 1,818
