跳转到主内容
Third generation of iPad with Wi-Fi, released on March 16, 2012. Model Number A1416. Repair requires heating and careful prying.
154 个问题 查看全部
问题已关闭
iPad 3 Wifi (2012) Flickering screen after screen replacement
Hi,
ive changed a few screens but recently changed an ipad 3 digitizer. everything is fine but sometimes the screen flickers, the ipad zooms in and out.
do you think this is a case that the digitizers are faulty or is this a separate hardware issue??
thanks in advance
DC
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
The flickering issue I would have to see to give a better diagnosis but if the ipad is zooming in and out, it sounds like some odd ghost touches that are a product of a defective digitizer. I would try another digitizer, possibly from another source if you are able, before I go any further to eliminate that as the perpetrator. Good luck!
这个答案有帮助吗?
得分 1
1条评论:
cheers Eric.
yes the ipad seems to act erratically zooming in and out. thanks for the reply
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 258
