跳转到主内容
The Lenovo IdeaTab A1000L is a 7-inch tablet that was released in 2013.
Why won't the charge port work properly?
I noticed a similar question from another customer, but have no answer. The charger/adapter port isn't making a complete connection, but the cord(s) is plugged in correctly. I'm not sure what to do.
Any suggestions??
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
2个答案
已选择的解决方案
Take a flashlight and look at the charge port on the device. Does it look damaged at all? Have there been any tumbles or other damage that might have occurred? It is possible that the charging port got damaged, or that there are clips on the cable that have become worn out.
这个答案有帮助吗?
得分 1
3条评论:
With flashlight, it looks like everything is fine. However, looks can always be deceiving.
It's possible that the port has been damaged, and possibly while still being plugged in for charging. The question that remains is whether or not it's cost efficient to repair it? Replace it?
Thoughts??
完成的
If you have data on the device that you need to get off and the device is dead, then it might be worth it to you to have it repaired. This charge port is a solder type, so you'd need skills with soldering and the right tools, or a shop that will charge a reasonable amount.
If data is not your concern, I would give you a subjective answer of no, it would not be worth repairing. You can find these tablets on ebay for under $100 (40-65 range) used but in good shape. The port itself you can pick up for around $10 or so. So, cost-wise, I would say that it is right in that range where it would be worth to repair if you were doing yourself or you required data off of the device.
However, I am of the mentality that if you can repair something, you should definitely do that over recycling or trashing it. You could donate it to many different charities or use it as a spare music player, or anything, really. Repair > Recycle > Trash
完成的
Eric, This is tremendous help; thank you!! I really appreciate your wisdom as well as the math equation; Repair > Recycle > Trash! Great help!!
完成的
添加一条评论
I'm having the same problem, but I open the tablet and the charging port came off from the moder board, how can I know were to connect each connection from the USB charging port ? Thanks n advance
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Barney Johnson 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 748
