跳转到主内容
Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66 GHz Core i7 Processors
Bluetooth Not Available after Module Upgrade
I upgraded Bluetooth module in a 2010 MacBook Pro, after doing so, I get a no Bluetooth device available message. My wifi, which I believe is part of the upgraded module, works perfectly. With that new module not working, I then reinstalled the old Bluetooth card and the message still appeared and Bluetooth was unavailable. I tried the resets outlined in many posts including SMC and PRAM. I am using yosemite. To help clarify, both cards are showing in system profile when they are installed in the network section. Bluetooth is where it says is missing. Any ideas?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Did you first enable Bluetooh in System Preferences> and then add a Bluethooth Service to your network? At the bottom of the left hand pane there are a + a - and a * (gear). Click the + and create a Bluetooth connection.
One other thing to try - from System Preferences make a new account and see if you can enable Bluetooth in it.
If this answer is acceptable please remember to return and mark it accepted.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
danielkite 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 222
