跳转到主内容
iPhone4S是第五代iPhone。网络制式为GSM/CDMA ,存储容量有8GB、16GB、32GB、64GB可选,机身颜色有黑色、白色可选。维修iPhone4S是容易的,需要耐心,用到的工具有螺丝刀、撬棒等。
2193 个问题 查看全部
Why is the dock connector cable port assembled on the back?
The dock connector cable runs from inside the iphone 4, wraps through to the top by the power button from an opening, and wraps on the back side of the device, where the cable and ports are attached by what seems to be some type of adhesive. I haven't even opened up the phone yet myself, because I don't have the tools. If anyone can tell me anything about this, or if it's fixable at all, I would greatly appreciate it.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
This makes no sense send a picture
完成的
添加一条评论
1个答案
已选择的解决方案
The dock connector cable does not connect from the bottom of the iPhone to the top as you describe. It goes from the bottom to the mid logic board connector, very simple actually. It does involve disconnecting the home button flex cable and removing and replacing the cover to the lower microphone. Here is the iFixit Guide for this repair. iPhone 4S Dock Connector Replacement
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
jasonwiggins1982 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 46
