跳转到主内容
标准款Xbox 360的轻薄升级款,配有250GB硬盘和Wi-Fi功能。维修需要用到复杂且特殊的工具。
Why won't my controllers connect?
I have an Xbox 360 S, and the controllers will not sync with it. I've tried everything I could find online, and even replaced the rf modulator. I tried plugging them in with a wireless controller with a charging usb cord, and that didn't work either. Any help would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
Do you have any wireless routers, microwaves or metallic objects positioned anywhere near your console? These can disrupt the signal or wireless controllers. As far as plugging it in to play that only works if you use the play and charge kit. Which asks you to connect the battery pack to the USB cable and that to the console. If after all of this still nothing is working your USB ports may be damaged, or the console itself may be damaged. If you can also try using friends controllers to test whether or not it is the controller that is malfunctioning.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Pat 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 7
总计 1,235
