跳转到主内容
苹果个人电脑产品线 iMac 系列的首款机型。 iMac G3 发布于1998年至2003年之间。
How to get out offlashing box
when it start a little box in middle of screen with a ? then 2 faces
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
You have lost your boot volume. Either the Hardware (HD) or the software (System Folder) is damaged or missing. You should be able to boot from your install or hardware test CD and repair the drive software (directory) or reinstall the OS if there's space on the drive.
Of course if you're not careful you can lose all your data with an improper OS install.
What was the last thing you did, or happened right before this behavior initiated?
If this answer is acceptable please remember to return and mark it accepted.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
dennis mitchell 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 70
