跳转到主内容
Motorola在被Google收购后发布的第一款手机;发布于2013年8月23日。型号为XT1058。
What part should I replace?
Hello dear,
I dropped my MotoX XT1052 today morning.
The screen were blinking with some colors and lines, then went to black screen.
Although everything is working fine.
I can unlock, receive calls using touch.
So which part do I need to replace?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
3个答案
Unfortunately the screen and lcd are bound together with adhesive. You will need to replace both... You might as well get a new phone like the dev edition of it and put on any custom back or buttons.
这个答案有帮助吗?
得分 0
添加一条评论
You may have rattled the internals. You might be able to take it apart and reconnect it. Sometimes it will disconnect, at least with iPhones. A cable may be loose though. You can just return it if its under warranty though, they should replace it.
这个答案有帮助吗?
得分 0
添加一条评论
You have to replaced the LCD , we can replace it at lower cost. More more visit: https://www.facebook.com/FoneZoneSolutio...
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Prakash Chavda 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 386
