跳转到主内容
Apple's 2012 first-generation 7.9-inch iPad mini, with 16, 32, or 64 GB of storage and an A5 processor.
Why is there a serial number in my new lcd display?
I have just received my new lcd display that I have recently order from ifixit last month (11/25/014)for my ipad mini, the repair went smoothly with just a few minor set back. After the installation
repairs, I turn on the unit, it power up the apple logo appears, no problems whatsoever. But I notice something. Half way down in the right side of the display, there appears a four digits, numbers 4904T. Thinking that I probably forgot to remove a protective sheet
from the display, remove the digitizer and check for the protective
sheet, but did not find any on the display. I have also check
the digitizer glass, but found nothing. Just to be sure, l turn on the
ipad without the digitizer glass, and chech the lcd display, the numbers are still showing on the screen. I have also open other
programs, like safari, apps, utilities, youtube and games, with the same results the numbers are still showing. Is this normal for a new lcd, if not how could I resovle this issue. Thanks.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
最有帮助的答案
The lcd should always have a protective sheet on it sometimes it doesn't look like it because it's on very smoothly. Take a thin blade and try a corner.
If no luck then try some alcohol on the numbers and it should wipe off.
这个答案有帮助吗?
得分 3
1条评论:
Its on the front side facing the screen had the same problem its clear and looks like its part of the lcd
完成的
添加一条评论
Is the character color for the visible serial number written in red? If so, I had the same situation and it was the protective screen cover. As ‘con’ stated all you need to do is remove the protective film.
Thanks
这个答案有帮助吗?
得分 2
1条评论:
you're a life saver dude
完成的
添加一条评论
添加你的答案
ramoncastro12 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 12
总计 2,191
